esim
Alg
Since I bought eSIM , my phone shows in settings under sims primary my tel number, then under used as travel no number no sim is this what it should look like
1 REPLY 1
hairbag1
@Alg
you could possibly have a hard sim from elsewhere occupying the second sim slot. That's when you'd see that number as travel or secondary.
