Transfer my number via eSIM
Chiajoulu
hi, I transferred my mobile from Rogers to public mobile via eSIM. At the beginning, outgoing calls work, but incoming calls and SMS still do not work. So I tried to delete the esim and install it again, but the eSIM QR code can't work. And then l can not access any cellular service currently, including phone calls and sms. Please help me resolve the problem. Thank you.
rai79
Hi @Chiajoulu
It looks like your phone transfer was not completed properly. If you didn't respond YES to the approve the transfer within 90 minutes, it can cause the transfer to get stuck. Not to worry though, I have sent you a direct message with the phone number that you can call to re-trigger the porting process. Please check your messages for the phone number to call. Unfortunately, I am unable to post the number in the community forum.
Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage )
HI @Chiajoulu
can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
but if it is not there you will need to ask PM support agent to help, you can submit  ticket by direct message:
Chiajoulu
I accidentally deleted my eSIM previously and then purchased a new one.  However, I can't install the new one via the app, and it continuously shows the following error message. Please help me resolve the issue. Thanks!
Chiajoulu
Hi, l purchased the new eSIM. But I faced a new issue that I cannot install the new one successfully.Screenshot 2026-01-26 at 20.51.55.png
Sansan
Deleting the eSIM was not something you are to do. So now you have to purchase a new one. If you cannot log into your account to buy a new one, you need to message PM agents for help.
hi @Chiajoulu
you shouldn't have deleted the eSIM, it was just a porting issue
check if you can login PM app to buy the new eSIM back, you need it.  Login App, go to Account, then Puchase sim card and choose eSIM
if you cannot buy eSIM back,  ask PM support agent to help, you can submit  ticket by direct message:
