06-14-2023 08:25 PM
Hi! After multiple attempts, eSim didn't install. I reset my network settings and rebooted the phone twice, still, could install. Can't open a ticket because I need a sim card number 😞 Any help would be greatly appreciated!
06-14-2023 09:35 PM
@RemiToussaint Please
Message support directly
06-14-2023 08:28 PM
HI @RemiToussaint if you have problem installing the eSIM, please submit a ticket to CS agent here:
06-14-2023 08:27 PM
@RemiToussaint are you activating eSim on iPhone or Android?
If eSim didn't install properly, likely support can resend you the QR code, please message support using direct message (yes, Chatbot ticket is not working, but direct message will work):
