06-14-2023 09:11 PM
I recently moved away from public mobile. I tried login in to my account and to the payment methods to stop the payments but i am unable to get to the page, i sign it but its like i am signed out. Please assist @CS_Agent
06-14-2023 09:41 PM
Thank you. I will reach out to CS Agent. Much appreciated
06-14-2023 09:16 PM
HI @adwance1
you can disable via *611 , but you need your 4 digits pin
or you can try to ask support to help by submitting ticket to CS agent:
Some people would try to stop the credit card for one or two days if you know exact when is the next renewal day (basically 30 days from last payment day)
06-14-2023 09:15 PM - edited 06-14-2023 09:33 PM
@adwance1 If you successfully ported your number out from PM you account is automatically closed , hence why you cannot sign into it anymore .. so no more charges should occur . You can also message support to remove credit card info also
Message support directly
06-14-2023 09:14 PM
@adwance1 if you know the 4 digits account pin, just dial *611 or 1.855.4PUBLIC and you can disable Autopay there
If not, you will need to try to login to My Account and remove it from Payment page
If your problem is unable to get to the page, try another browser, try Incognito mode
if you problem is 2FA code cannot set to your phone, then try these workarounds:
If none of those workarounds helps, please open ticket with support and have them to help in this situation:
