04-15-2025 10:29 PM
I lost my eSIM login details. Please help me
04-15-2025 10:43 PM
Thank you
04-15-2025 10:37 PM - edited 04-15-2025 10:38 PM
First, please remove your email from the post. This is a public forum. Click the arrow down and edit.
If you do have to pay for one, don't worry, you can simply create a ticket and a CS Agent can credit your account.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
04-15-2025 10:36 PM
Pay the esim first
Then ask PM to reimburse after all setup
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
04-15-2025 10:36 PM
I’ll have to buy a new one?
04-15-2025 10:35 PM
You lost your esim or you lost My Account login?
If you just lost the logun details, try Forgot email and Forgot Password on the login page. Or ask PM to sort it out
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
If you just deleted the esim and need to get a replacement one, just login to the Public Mobile app on the phone. Use email to receive 2FA code. After logging into the app, go to Account ->Purchase sim card and buy esim there
04-15-2025 10:34 PM - edited 04-15-2025 10:39 PM
At checkout it’s still charging me $5.75 please.
04-15-2025 10:33 PM
