04-15-2025 11:05 PM
I paid for the subscription. But it doesn’t port my number and gives error each time. Please reach out or refund the charge
04-15-2025 11:12 PM
Thankyou. It gives error at the last step. I messaged them. Thanks for guiding me
04-15-2025 11:07 PM
What error did you get?? Did you get the error at the step where you put in your old number to be ported or at the last step of the Subscription process?
You can ask PM to help to sort out that activation issue, or ask for refund if they cannot help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
