09-12-2024
07:54 PM
09-12-2024
08:19 PM
computergeek541
I recently signed up and eSIM worked, do I need to remove my old SIM card from previous provider?
09-12-2024 08:17 PM
Hello @Tomate
As long as you've set your Public Mobile eSIM as your primary and you can make and take calls, make and receive text messages and also try some data like surfing google or use an app or two to make sure your data works, then for sure. You can remove your old providers SIM card. If you do have issues with anything above, please come back here and let us know. One of us will show you how to get more help.
09-12-2024 08:16 PM
You don't need to remove the old physical SIM card (however it'll be unusable after the service is ported to the new e-SIM)
What's important is that under your device's cellular settings, that your device is 'pointing' toward the e-SIM to receive PM service from it.
I'd recommend you do remove the physical SIM card and discard it after all PM services are working on the e-SIM.
09-12-2024 07:56 PM
you are porting in your number from the old provider?
if you are, did you get a message from the old provider and did you reply YES? Wait for the text and you can remove the other provider sim card after you reply YES
and for your PM sim card, make sure you test incoming calls on your PM sim card to confirm the port is completed
