yesterday
how to change my subscription to less amount. I am lowering the amount of my subscription
yesterday
Each existing customer has personalized list of plans that are available to them. Check your self service account to see which plans are available.
Unfortunately, many of the plans offered to existing customers are not cheaper. Usually more expensive.
yesterday
@delos to see what's available to you, sign into your account and click on Manage Subscription.
There is not a lot of lower plans unfortunately.
When you decide to change, use the option that says Change on Renewal to finish you current cycle as there are no pro-rating.
