e-sim
08-24-2023
02:17 PM
08-24-2023
02:21 PM
computergeek541
So I have two phones that I currently use, one is for work and one is for personal use. Am I able to use one of the numbers as an eSIM number on the other phone?
Phones
08-24-2023 03:19 PM
08-24-2023 03:16 PM
Yes but you'll have to have both the numbers on seprate Public Mobile Accounts.
You can only use one e-SIM at a time, but you can use both an e-SIM and Physical SIM at the same time, almost like a Dual SIM Phone.
08-24-2023 02:33 PM
HI @Terry1973
First, we need to find out what phone you have to see if your phone support eSIM
You see one tray, and that is for Physical sim card, but it could also support eSIM which does not need a tray
tell us what phone you have first
08-24-2023 02:32 PM - edited 08-24-2023 02:34 PM
@Terry1973 Yes because one phone number you’re keeping in physical SIM card correct . The other phone line you want on eSIM . So the eSIM line will install on the phone you choose to use say for personal . Then the physical SIM card for say work goes in that SIM card tray of the phone you installed eSIM on
08-24-2023 02:30 PM
The tray on my phone is only one? Do u mean to just imput the sim card number from the other phone in?
08-24-2023 02:26 PM - edited 08-24-2023 02:28 PM
@Terry1973 In the PM app go to subscription add on page and buy eSIM for the phone line you want on eSIM bottom of page shop sim . Select it and pick eSIM and instal . And then put the SIM card from other phone in the phone you have eSIM on . But in it’s SIM card tray
08-24-2023 02:23 PM
How do i go about doing that? Both of my phones support eSIM I just don't know how to transfer from one phone and add to the other.
08-24-2023 02:21 PM
@Terry1973 wrote:So I have two phones that I currently use, one is for work and one is for personal use. Am I able to use one of the numbers as an eSIM number on the other phone?
This can be done only if the phone supports eSIM and if Public Mobile allows eSIM to be activated on your device.
08-24-2023 02:20 PM
@Terry1973 Yes
