02-06-2025
10:35 AM
02-06-2025
10:39 AM
computergeek541
the new physical sim is taking a long time to activate. how long does it take to switch from an esim to sim?
if I have a defective sim, how I exchange it?
02-06-2025 11:09 AM
hi @nishin
for one line, it doesn't really matter, but still you can try change it back to Primary
02-06-2025 11:05 AM
I disabled the esim before restarting. I don't understand the difference with two lines showing up but by turning on the business line, the SIM activated immediately even though I only have one phone number.
02-06-2025 11:02 AM
hi @nishin
do you have another esim there? you might still have your old Public Mobile esim or other carrier's esim, disable them (or even delete them)
02-06-2025 11:00 AM
I turned on the "Business" line and now my sim is working. I don't know why I couldn't use the regular line. I only have one phone number.
02-06-2025 10:51 AM
restarted and confirmed my phone is unlocked. still nothing. I have sent a message to support.
02-06-2025 10:47 AM
Try rebooting your phone by powering off then back on and see if SIM works.
02-06-2025 10:37 AM
hi @nishin
usually it is fast. But you might want to ask support to confirm on the system. If it is really a physical sim problem, they can either send you another one, ask you to buy another one from stores close to you and reimburse the charge
Check with PM support agent first. You can submit ticket by direct message:
