08-30-2021 11:41 AM - edited 01-06-2022 03:18 AM
I have been using my phone for talking only but data time is getting used every day, anywhere from 2 to 42 megs per day. Where are my megs going?
Phones
08-30-2021 12:37 PM
Managing Your Data Usage visit Here link , to save your data..
08-30-2021 11:58 AM
Are you on Android? The quick way is to use Data Usage in the setting menu. Set the Cycle start date to today (or yesterday), then you will see which app used the Mobile data
A long term solution I recommend is to install some data tracking app that does 30 days cycle and not just Monthly (as PM is running on 30 days cycle). You will set it up once with the cycle date, then you can tell which app used how much in each cycle and the total data consumed.
On Android: Data Witness PM, Data Counter Widget
On iOS: My Data Manager
08-30-2021 11:50 AM
@mikelukow : Your phone will use the internet for OS updates, app updates, app notifications etc. Go through all the apps and turn off background data usage for those you don't want to use data. Set OS and app updates to only happen when on wifi.
And yes...turn off cell data when not intending to use it.
08-30-2021 11:50 AM
You need to manage your data by the settings in your phone.
Example: For some applications I turn off background data.
08-30-2021 11:46 AM
@mikelukow wrote:I have been using my phone for talking only but data time is getting used every day, anywhere from 2 to 42 megs per day. Where are my megs going?
Go in to your settings and turn OFF data until you need it.
