Usage of internet
09-05-2021 04:01 PM - edited 01-06-2022 03:18 AM
Hello
I haven't been able to use my internet for the last few days
Please help
Thank yoi
Service
09-05-2021 04:11 PM
@Atifa1984 wrote:Hello
Please help
Thank yoi
Log into your Self Serve and make sure your Data Line shows up under your Overview page.
If it does not show up, than that normally means you have used up all your Data allotment for this cycle.
If you DO show a Data Line under your Overview page, ensure your DATA is enabled, and perform a RESET of your NETWORK SETTINGS.
09-05-2021 04:06 PM - edited 09-05-2021 04:07 PM
do one thing Make sure your phone is off before removing your SIM card,
and take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
and if still not fix it please you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here link to get started.
- or you can send a private message to Customer Service by CS_Agent, by Click Here link.
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your account number,
- your phone number,
- your account 4 digit pin,
- your Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
Good Luck
