data usage does not add up
stewfrei
data has been turned off to my phone saying i have used 60gigs (what is in my plan) going into my account under data usage and adding all the transfered data numbers up does not equal anything near the 60gigs in my plan and the data tracker on mky phone says only 30.45 gigs used since my plan renewal last month.
2 REPLIES 2
HALIMACS
@stewfrei
The  Public Mobile data counter is likely correct.
Try clearing your system cache and cookies, and using an incognito or private tab to login to the self-serve site.
If you’re using the app, try using the web-based site, or vice versa.
When you are on the site, tap those little refresher icons to ensure you’re getting an up-to-date version of the webpage as there can be caching issues with the site.
Chalupa_Batman
If you feel your data usage should only be 30GB and it says you used 60GB already, you can reach out to a CS Agent to investigate and give you the answer why.
