data redeemed with points
chansimons2007
Is there a time limit to use the data I redeemed with points?
chansimons2007
Very good to know about the US roaming. Thank you.
darlicious
@chansimons2007
Unless you redeemed points for US Roaming data or add ons then they have a 15 day (360 hour) expiry that starts as soon as they appear in your self serve account. All other add ons do not expire they roll over every 30 days until completely consumed.
HI @chansimons2007   smart to use the points for data add-on (or any add-on), it is cheaper than buying
@chansimons2007   No time limit
All add-on that you purchased or redeemed with points DO NOT have an expiry. They will be there until all used
@chansimons2007  No it will roll over till it’s all used
