data only works for some apps
sahands
some times like today, I have my data on, and it was only working for certain apps like the browser, but not others like google map: could open it, but could not navigate or search, when I connected to wifi then maps was working.
23 REPLIES 23
Leeoku
was able to solve turns out my apn was pointing to koodo not public after i switched sims
@Leeoku
Can you post your APN? It sounds like you connected briefly to free wifi. You likely need to edit your APN to public mobiles.
Edit:
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
Leeoku
Im on  a oneplus 6 and just had this happen to me. I switched from Koodo so I'm sure it worked. When I was out trying to use it for the first time, none of my google apps can connect but browser was fine. Couple minutes later and possibly in another area, google maps is fine.
Not sure if fully solved, will have to wait and try..
sahands
That wouldn't be an issue, since maps works fine on both wifi or data when I'm at home.
Unlikely, because Google Maps doesn't require much data either.
@sahands wrote:
I have another hypothesis, what if data coming from that tower is very slow? Could it be that the web browser on my phone can load simple pages quickly and efficiently on slow data connections, whereas google maps requires a fast connection to load things like traffic and directions?
@sahands Yes, if there is network congestion that would be a valid assumption to make.It's happened to me also but only when there are large gatherings like a sports event or a concert.
mh1983
Have you granted Google Maps the appropriate app permissions?
sahands
@sahands wrote:
It seems to be a cell tower issue based on location.
The cell tower doesn't have the capability to do that. Not to mention towers are owned and operated by Bell in the GTA.
sahands
My phone is set to use 4G.
The issue that other forum users had with their forum is not really the problem that I'm experiencing.
I was in oakville today and had no issues there using my maps. It seems to be a cell tower issue based on location.
srlawren
@geopublic wrote:
@sahands wrote:
Xiaomi A2 lite on Android one (version 9)
@sahands Is your phone connecting to LTE or 3G for data? Best to connect using LTE or 4G. Sometimes if the network is congested it's possible that the browser will work but other more data intensive apps drag. That phone supports two sims make sure your using sim 2.
@geopublic this seems an unlikely cause for this problem.
@sahands it looks like you may not be alone.  Here are some threads from the Xioami and XDA forums which may be helpful?
https://c.mi.com/thread-2198584-1-0.html
https://c.mi.com/thread-1687989-1-0.html
https://forum.xda-developers.com/mi-a2-lite/help/mobile-data-issue-pie-update-t3884664
sahands
srlawren
@sahands wrote:
I think it's just PM that's screwing with me 😞
@sahands it's not.  As @computergeek541 noted, data is just bits in a pipe.  What phone are you using?  Brand, model, and operating system version?
Please don't mark your own posts as solutions.  I hope that someone is able to help you figure this out.  I can't see any reason for Public Mobole would care which app is being used. It's all the same bandwidth to them.
sahands
@sahandsNope cellphone towers don't care what app it is using data.
sahands
So it happened again today, I restarted my phone, and still the same thing, I checked my browser and it was working fine. After I made the trip out of town and got home, I tried the data again, this time maps was working fine!
So it seems odd, but could it be that the cell towers in certain areas are blocking certain apps from using data????
LeafLife
A simple way is to take your sim out of your current phone and try it in another phone. This should tell you if there are restrictions on your phone preventing the Data use in that particular app. Simple way to test things at the very least.
oglat
Also check data restrictions
See if you gave all the needed permissions for maps to operate
Can you test it on another phone?
Recovery
Make sure cellular data usage for google maps is turned on through your phone settings. If it is already enabled, try restarting your phone.
Triguy
Check your settings.  Google maps can be set to only work when connected to wi-fi.
will13am
@sahands , what phone do you have and is there any kind of firewall app running that is selectively enabling data?  Public Mobile does not manage how your data is used.  If the data works to your phone, it should work for all apps.
