05-09-2018 11:24 AM - edited 01-04-2022 04:14 PM
data is not working and yes I do have data and yes I followed the steps for my android phone to connect to public mobile
05-09-2018 05:01 PM
@dylanmclauchlan did you reboot your phone? Usually needed after making APN changes.
05-09-2018 04:15 PM
Hey I'm not OP, but I'm having the exact same problem.
Data not working. I still have 1500mb left in my plan. Also I'm getting good reception, and my data has worked for months, this is the first time it stopped.
I tried the steps above to change the APN, but it still doesn't work.
05-09-2018 12:22 PM
@lorianferes since you set @NDesai's reply as solution, I presume setting your APN has resolved this, and you're all good now?
05-09-2018 11:27 AM
Double check your APN settings with the settings found on this site: https://apn-canada.gishan.net/
You might want to try deleting the existing APN and add new one.
