10-28-2020 10:51 AM - edited 01-05-2022 03:55 PM
How do I add data only to my plan so that I can use data only in the Caribbean?
10-28-2020 05:52 PM
@geopublic wrote:@viewfinder Public does not offer roaming data add-ons for the Carribean. Best to check Amazon and purchase a prepaid SIM or purchase a local sim from the airport once you arrive
Last I checked, Puerto Rico and some islands to the east that are also included are considered to be in the Carribean.
So admittedly the OP asked way too broad a question.
10-28-2020 05:09 PM
10-28-2020 04:56 PM
- login to your self serve
- click the plans add-ons tab
- click on my add-ons
there are 3 different us roaming data add-ons to choose from
$10/250mb
$15/500mb
$20/1gb
*be sure to add money(credit) to the account as "available funds" before choosing the add-on you would like
you can also dial 611
10-28-2020 11:01 AM
You would need to either pu6 a local sim or use Gigsky. If you have access then you could use Wi-Fi.
10-28-2020 10:56 AM
@viewfinder only add-on is the USA roaming add-on which covers these places.
Your U.S. coverage will include all 50 states, plus Puerto Rico and the US Virgin Islands. So, whether you are travelling to the snow-capped mountains in Alaska or to Hawaii’s sunny beaches, we will have you covered.
Other than those places there are no other options that Public Mobile has available.
10-28-2020 10:54 AM
There are no data add ons for the Caribbean. You must get a local sim.
10-28-2020 10:53 AM - edited 10-28-2020 11:14 AM
@viewfinder wrote:How do I add data only to my plan so that I can use data only in the Caribbean?
For the few American protectorates that would have AT&T or T-Mobile, you need to deposit money into your account and then buy the data-only roaming add-ons. Then make sure you have data roaming on in the phone.
Edit: @viewfinder : the coverage maps of both AT&T and T-Mobile show what's available for the area.
I wonder if any folks here have had experience with Public Mobile on other islands that aren't mentioned in the add-on blurb. But show on AT&T as "off-net" under international.
