current data period
rdogg
Hi
I just noticed that my data for my current period is showing 48.5 GB which would be impossible as my new month just started today Aug 17 . I was just wondering if this is normal ? My first month was last month and i used under 2 GB so Im just wondering if this happens every time i start a new month ?
 Thanks
9 REPLIES 9
srlawren
@gblackma wrote:
@rdogg that's probably your data usage for the whole time the phone was in use. You never set your data usage tracker. Stay safe.
@gblackma likely, yes.
@rdogg is this an iPhone, by chance?
@rdogg  You need to sync your plan's start date with the start date on your phone's data usage app. Select the period to be 30 days or monthly.
dabr
@rdogg wrote:
yes it is showing GB i just double checked
@rdogg   It's more important what your account shows.  Log into your account and take a look under My Data/Add-ons to see how much data you have available as your phone counter may not be showing the same timeline as  your account cycle.
rdogg
rdogg
it is on my phone
srlawren
@rdogg wrote:
Hi
 Thanks
@rdogg to be clear: are you sure it's showing 48.5 GB and not 48.5 MB ?
kb_mv
@rdogg Post a screen shot of your self serve account page showing this. It will give us a better idea of what's going on. Remove personal info from the screenshot first.
@rdogg wrote:
Hi
 Thanks
On your phone? Or the overview counter?
If the overview counter then perhaps it's actually MB.
