04-19-2022 04:51 PM
Do I need to update my credit card info when only the expiry and the SC changes (I received a new one; same number, just these other 2 factors changed)?
07-14-2022 03:38 PM
I can not find this "Manage my card" on the site
04-19-2022 06:04 PM
It's. A pretty easy process if you follow those steps... In fact you can hop back and forth with different cards whether it's just different expiry dates or even prepaid or vanilla type mastercards if you want to use it for a renewal or 2.
04-19-2022 05:59 PM
Before logging into your self-serve account to update your credit card, recommend following this procedure to avoid the common glitches that sometimes occur with this process:
04-19-2022 05:18 PM
@frazerhk wrote:Do I need to update my credit card info when only the expiry and the SC changes (I received a new one; same number, just these other 2 factors changed)?
@frazerhk if you are looking to see where to do this at, go to the PAYMENT tab in your self serve account, and see the bottom, left corner of this area shown below.
There you will need to remove or replace the one that is listed, then add the new one in.
04-19-2022 05:16 PM
Yes you need to login to your account in Make A Payment button then change your CC information.
04-19-2022 04:55 PM
Yes, you should update it. Although some merchants are able to receive infromation about updated cards directly from card issuers, I have not received any indication that Public Mobile practices this.
