contact a moderator to enable login?
02-20-2019 09:46 AM - edited 01-05-2022 03:25 AM
Why was my login disabled after not using SIM for a few months? How do I re-enable and reset?
Joining Public
02-20-2019 10:47 AM
Your account will be suspended if payment is not received on your rate plan renewal date, and will expire/deactivate on the 90th day. That also means that on the 90th day you would lose your telephone number associated with your rate plan and your self-serve account will be disabled.
Your old SIM card will not work either and you need buy new SIM also create a new account and I hope this helps .
02-20-2019 10:11 AM
If it was not so long (90days) you will need help from the moderator here...
And explain what happened...waiting time few hours to 2 days... @michbg
02-20-2019 09:48 AM
@michbg wrote:Why was my login disabled after not using SIM for a few months? How do I re-enable and reset?
If an account goes into suspension for more than 90 days then everything about the account is gone.
You would need to buy a new SIM and activate a new service using a different email address.
