10-17-2017 06:26 PM - edited 01-05-2022 03:25 AM
I recently switched to Public mobile. I was in trouble since day first. I paid 177 dollars for 90 days. I had no service for the first 48 hours, Now after two weeks Public mobile de-activated my service and a moderator advised me to buy a new SIM. I didnt asked for de-activation but I have to go to walmart, buy a new SIM, spend a few hours again on computer texting moderator for to activate a new SIM.
Unfortunatley it is my fault, I signed up with company where they have no live person to resolve my issues. I wish I can get my money back, say sorry and switch back to Koodo
10-19-2017 07:26 PM
@JUAN7 could you maybe be a little more specific?
10-19-2017 12:25 PM
I'm having a problem refreshing my plan
10-18-2017 08:27 AM
@mpcdesign wrote:I was just reading your post. I had an issue when I first started with Public Mobile, but I found my answer by finding that I did not set my phone correctly. I started on the cheap plan of $126 for 3 months.
Try this out.Step by Step APN configuration
Step1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Click here
Then use the steps as is:
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
Thanks
@mpcdesign, the APN settings affect data functionality. OP's issues are different.
10-18-2017 03:44 AM
Try this out.
Step1:
Android
Blackberry
Windows
iPhone
Click here
Step 2:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
Step 3:
Thanks
10-18-2017 12:45 AM - edited 10-18-2017 12:46 AM
This just doesn't sound right. Why would there be a restriction on how many devices the SIM card is used on? I am sure there is a logical explanation for what happened. It would be nice if someone from the Public Mobile end clarify if there are such limitations.
@toroser, if the deactivation was through no fault of yours, I am sure that you can work something out with the moderator team to be reimbursed for the new SIM purchase and any lost service time. They are very fair.
This service is not the panacea. There are issues with the service, it is not for everyone. However, the lack of a call centre is not one of the problems.
10-17-2017 09:20 PM
10-17-2017 07:45 PM
10-17-2017 07:16 PM
(1) Thank you for your reply in regards to your service issue toroser. That being said, after having verified in our systems, I can confirm that unfortunately your SIM card has been deactivated on 2017-10-15 and I sincerely apologize for it. Now, please click on the following link to see which Walmart store sells Public Mobile SIM cards nearby : https://www.walmart.ca/en/store-finder You may also see which WOW! Mobile
(2 )Thank you for your reply in regards to your service issues. That being said, after having verified in our systems, I can confirm that your SIM card has been associated to 3 different devices in the past month : first it was associated to device with IMEI 3-------------, then 8-------------, and then ------------. Now, after having verified in our systems, I can confirm as well that there is no technical.
10-17-2017 06:53 PM
Hello toroser,
Thank you for reaching out to us.
I am sorry to hear that you do not have service yet since you have been subscribed with us.
In order to better assist you, please send us a private message.
For more information about how to use the Community service, please refer to this link: https://productioncommunity.publicmobile.ca/t5/Announcements/Changes-to-our-Support-structure/m-p/16....
I am looking forward to your reply.
Kind Regards
Abdoulaye
10-17-2017 06:51 PM
Yes moderator is saying that Public mobile has de-activated your service becuase you used your sim on three different devices ? isnt that funny answer
10-17-2017 06:46 PM
So is the mod saying your account has been deactivated because you have used your Sim in 3 devices, or saying the Sim may be defective due to switching between devices?
10-17-2017 06:40 PM
I sent private messages to Moderator. He/She is advising me to buy a new SIM. Why should I buy a new sim? I didnt asked for de-activation. Moderator is telling me that you have used your sim on three different device in one month. It is my choice which device to use, public mobile should not restrict me to one device.
10-17-2017 06:30 PM
For activating your SIM, you don't have to message the mods; just go to my account > plan and add on > change SIM. As for wanting to switch back to Koodo, being pre paid you likely won't be able to get your money back, but you could try asking the mods for a refund. If they are able to do a refund be sure to transfer your number over before your account is terminated, or ask the mods how long your number is good to transfer over after your account is deactivated.
Also sorry you had a bad experience setting up your account. Public Mobile is pretty good though once you get started.
10-17-2017 06:29 PM
I understandd that you are furious, but you have to understand that public mobbile offers such cheap services because they cut down on customer service and other things related. it is weird that your account is being messed up but i assure you, once the moderators help it should be a breeze . @CS_Agent and it looks like this can only be fixed by the moderators. just send them a direct message with your phone number and account number for security reasons and they will help you. wish you the best.
