01-13-2022 07:03 PM
Sorry, but does anyone know if this phone is compatible? Can't find its exact match in the list. Thank you!
Motorola Moto G Play (2021) 32GB 6.5" Display 5000mAh Long Lasting Battery XT2093-3 Unlocked Smartphone
01-13-2022 07:41 PM
As long as it can handle PM's frequencies, you are good to go!
If you have that phone in your hand, try to find somebody with PM service and try his/her SIM. That is the best test 🙂
01-13-2022 07:06 PM - edited 01-13-2022 07:07 PM
Yes it is, @Lise01
See here:
Will Motorola Moto G Play (2021) work in Canada? (kimovil.com)
It has the necessary bands for Public Mobile service.
01-13-2022 07:07 PM
Yes it will work no problem.
01-13-2022 07:16 PM
HI @Lise01 Usually big brands like Motorola or Samsung are pretty save these days in terms of compatibility, but AS LONG AS they are North American variant
is your from US? T-Mobile? If that is the case, make sure the phone is unlocked. And even unlocked, it might or might not get OS update. Some phones, even unlocked, is getting the OS updated from the carrier instead of from manufacturer. And some US carriers only push down the update if the phone is registered on their network.
01-13-2022 07:21 PM
Yes is will working with Public Mobile.
visit Here link to review full information,
Public Mobile uses the following frequency bands:
visit Here link, to check it all Provider in Canada about compatibility with any device.
01-13-2022 07:41 PM
01-13-2022 07:48 PM
Thank you, everyone!
