03-30-2023 09:57 AM
I recently dropped my plan from the $45/20GB plan to the $40/15GB plan. I do not read it anywhere, but is everything that same, including voicemail with the $40 dollar plan ? - other than the amount of data of course ?
Plans
03-30-2023 11:58 AM
Yes, I agree with the below, these plans have all the same features and with this plan, you still have 4G speed.
03-30-2023 10:13 AM
HI @johnny5 other than the $15 plan with limited minutes, all others plans are only differ by the amount of data included, and the of course, the low end plans are 3G speed while any plan $35 and above are now 4G speed
If you don't use up the data, $40 plan is the best in value one. You made a good choice in switching
03-30-2023 10:12 AM
03-30-2023 10:10 AM
@johnny5 Yes everything the same except the obvious $5 and 5Gb difference
03-30-2023 10:04 AM
You are correct. All the features of the plans are the same except for the data amount per 30 day cycle.
