Phone stuck in sos
Peteresser
My phone is stuck in sis mode tried all the resets
20 REPLIES 20
@Peteresser wrote:
I have checked the blacklist and phone is okay not listed as lost or stolen
@Peteresser With what Apple said, it sounds like this.  The carriers' own blacklist and the national list could be could days out of sync.  So, best to open ticket with PM Support and have them confirm
When you do a full power down restart do any messages appear? Have you tried another sim in the phone? Preferably Telus or Koodo?
Peteresser
@Peteresser   that sounds like the phone was blacklisted
Please open ticket with PM support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Peteresser
Contacted Apple and they say carrier rejecting phone does PM have anyone we can actually talk to
@Peteresser   did you get the phone from Apple or from another provider?
and it is best to test your phone with another sim card if you can borrow one from your friend.
@Peteresser
@Peteresser wrote:
Yes did the factory reset
and IPhone 13
Not a PM service problem.
So you may want to contact apple support to see what is happening.
Is phone still under warranty?
Peteresser
No it still says SOS after putting it back in
Peteresser
and IPhone 13
@Peteresser wrote:
Put SIM card in another phone and works fine
@Peteresser
If your PM SIM card works in another phone, then it is a device/phone issue.
Good to hear that the phone is not blacklisted.
Did you try a factory reset of phone?
What model phone?
HALIMACS
@Peteresser
if the Sim card works in another device, then it’s definitely a device issue and not a public mobile service issue.
When you put the SIM card back in your original device, does service work again? The simple act of removing and reinstalling the SIM card may do the trick.
@Peteresser wrote:
Checked blacklist and not listed as lost or stolen
HI @Peteresser   it could be a fault phone then.
See if you can find another active sim card and test this phone
HI @Peteresser   where you bought the phone from?
Check the devicecheck link provided above, it looks like blacklisted phone, especially if you bought privately
Peteresser
Peteresser
HALIMACS
Try the device checker first, @Peteresser
ESPECIALLY if you purchased the device from an unknown source ( ie not a retailer )
https://www.devicecheck.ca/check-status-device-canada/
Peteresser
Yes account is active I can try it in another phone to see what happens
@Peteresser wrote:
Working fine for months until yesterday
@Peteresser
Is your account status active?
As mentioned, check the IME of your phone on the blacklist checker. Likely fine, but good to rule out.
Might want to try the SIM card in another working phone. This helps determine whether hardware issue versus PM service problem.
Peteresser
Dunkman
@Peteresser
When and where did you purchase your phone?
Did it work before?
By chance, is your phone blacklisted for some reason?
Check this website:
