combined acct
jerthomas
is there a possibility to have one account for two numbers?
7 REPLIES 7
@computergeek541 wrote:
@jerthomas wrote:
my password not working how do i reset it
The first thing you'll need to try will be going to:  Public Mobile - Forgot Your Password?
@jerthomas  - were you able to get your password reset with the above link?
If you had too many failed attempts, wait 15 mins+ than try again.
If still issues contact CSA to help you get back into your account.
If you did somehow activate two accounts with one email then you will need CSA's help to assign a unique email to the 2nd account.
Contact CSA's by either two methods found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
HALIMACS
@jerthomas
No, but you CAN use the same payment card for both accounts, if that's any consolation.
jerthomas
darlicious
@jerthomas
No unfortunately not. You can use an email alias to make it a little easier for pm info to be recieved on one email account but accounts must have separate emails.
LeePublic
No, PM states one number per account.
