05-07-2023 07:22 PM
05-07-2023 09:09 PM
Problem. Add-on switch completed. all is well
just told to reboot phone
for US min instead of US roaming
Tks all for yr solution assist
05-07-2023 09:01 PM
secs ago CS_Agent provided correction by reply to him. awaiting now.
05-07-2023 08:55 PM
@TCsafeway Just wait for response explain what’s happened and ask them to reverse it for you or give you a credit on your account to re buy the proper add on you wanted .
05-07-2023 08:46 PM
I just submitted a verification code sent as text msg
and sent msg to CS_??
"what next?"
05-07-2023 07:56 PM
@TCsafeway support usually reply within couple hours. I suggest you to simply come. check every hour or so to check
05-07-2023 07:38 PM
watching envelope btw
05-07-2023 07:37 PM
typical response time?
should I stay logged in here?
05-07-2023 07:29 PM
Used yr link msg sent CSagent. awaiting reply
05-07-2023 07:23 PM
@TCsafeway Reach out to support they should be able to help you
Watch for reply top of page to the
Right ( envelope image )
