01-02-2024 01:09 PM
When I signed up, I chose the wrong plan by accident. How do I switch to the correct plan? I meant to select the $29/month option with 30GB of data.
01-02-2024 02:51 PM
If you can look into "My Account", try to click the icon "change subscrition" then choose the right one to switch it youself.
Otherwise contact CS_agent for help, All Public CS_agent is very nice!
01-02-2024 01:30 PM
@VictoriaMarie wrote:Thanks, I will do that.
watch the little envelop icon on top right side of page will be highlighted when they respond. Make sure to include as much account info when you message them...ie: phone number, account number, old cell provider ..etc.
01-02-2024 01:25 PM
01-02-2024 01:23 PM
you can try to message the Customer Support agents using this link...
