03-27-2024 06:21 PM - edited 03-27-2024 06:22 PM
Two Things.
1. I just transferred my number from Virgin to Public, eSIM to eSIM, but I am not receiving the 6 digit text code to confirm my identity. I've performed a hard reset, but still no luck. I can make calls and do everything else.
2. I mistakenly chose the wrong plan, as I wanted the 60GB Canada-US plan. Can someone from the support team assist me with this adjustment, since I am new to Public and need this changed.
Thanks!
03-27-2024 07:14 PM
@Hywrd - If it doesn't show up in the sent messages box (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage/tab/outbox)
Yes, then send another ticket to CS_Agent. If the ticket you created when you have private messages disabled worked, then they should reply within 48 hours of your ticket.
03-27-2024 07:06 PM
Private Message is now turned on. Do I send a new Ticket then?
03-27-2024 06:56 PM
03-27-2024 06:51 PM
03-27-2024 06:25 PM
@Hywrd , have you enabled the Public Mobile e-SIM in the SIM manager? I believe you need to set the Public Mobile e-SIM to active and make it the primary talk and text. As for switching plans, if you cannot tolerate keeping the plan you accidentally chose in error for the next 30 days, you will need to ask support to help with an immediate plan change that will not involve losing the payment for the current plan cycle. Use the chat symbol on the lower right corner to initiate a support ticket.
03-27-2024 06:24 PM - edited 03-27-2024 06:26 PM
Hey @Hywrd
To reach a Customer Service Agent, click on the chat bot at the bottom right corner of the page.
WIth regards to getting the code, here's how to send it to your email instead.
Can’t get the 6 digit 2FA code to your phone?
First, sign into your account at www.publicmobile.ca and use the email you signed up with and the password. If it asks you for a 6 digit code, it will say at the top left CONFIRM YOUR IDENTITY.- Enter the 6- digit code sent to *********. But it’s not working!!! As you see by the screenshot below, 1. Click the This is a trusted device. 2. Didn’t get the code? Click on that.
Then, the next window that pops up is this.
Click on Send email. Here it will send you the 6 digit code to the email you registered with. This step is very important. Do not just copy and paste. Enter each digit using your keypad.
You should now be able to get into your account.
Created by Chalupa Batman
Page froze when I added this. LOL
03-27-2024 06:24 PM
@Hywrd Did you reply yes to the confirmation text from old provider ?
you can reach out to support and they may be able to help you change to correct plan
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
