03-16-2023 05:10 PM
Hello,
How do I change my email address associated with my public mobile account?
Thank you.
My Account
12-17-2023 12:08 AM
Update: We can now change our email address (web or app).
Within the profile settings click Manage EverSafe ID and just click the arrow beside your email. If you get "Login Error" you may be trying to use an email that is already associated with an account, if that's not the case contact help.
Here is a post with screen shots
https://productioncommunity.publicmobile.ca/t5/Get-Support/How-to-change-login-name-email-address/m-...
03-16-2023 05:26 PM
03-16-2023 05:13 PM
HI @jrkmpspence you cannot do it yourself, you need PM agent to help to change the email address used on My Account
Please submit ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Forgot Login,
03-16-2023 05:13 PM
Unfortunately you'll need CS Agent to help changing the email address. You'd think you can change on the account, but you can't.
You can contact an agent using the chatbot. Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
