06-29-2026
07:55 PM
- last edited
2 weeks ago
Dunkman
I am unable to update my address through my profile keeps saying invalid when it is not
06-29-2026 08:11 PM
Yes, the address database might not have all addresses. In this case, you need PM to help to put it in for you
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
06-29-2026 08:05 PM - edited 06-29-2026 08:06 PM
@Josh47 wrote:I am unable to update my address through my profile keeps saying invalid when it is not
Hey @Josh47
The system can be a bit finicky at times. Honestly though, it doesn't matter what address you enter. Public Mobile doesn't care where you live. 🙂
You can even use your work address if you wanted. Not like they mail anything to anyone as all communications are through this forum and emails.
