01-26-2023 10:52 AM
Hello everybody.
I like keep my old rewards system,If I change to new plans will it automatically enrolls into the new points system?
Thanks.
01-26-2023 12:05 PM
Completely understandable why you'd think this.
Public Mobile advertises it Points Plus details on plan descriptions and this may cause some unsuspecting users to 'believe' they must switch to be eligible for the different plan.
They are pretty sneaky.
Good on you for checking here first!!!
01-26-2023 12:04 PM - edited 01-26-2023 12:06 PM
@francis100 as you already aware now you won’t lose rewards they are tied to your account not the plan your on so go ahead and choose whatever plan suits you best
also you will only switch to points if you choose to it’s a one way street and you cannot go back to rewards if you ever choose points .. consensus around here’s is stick with old rewards
01-26-2023 11:13 AM
@esjliv
Thanks, I had to re-read the question the first time. Yes @francis100, I mean you need to voluntarily agree to switch to the new Points system but you are fine to switch plans.
01-26-2023 11:04 AM
@francis100 , @BKNS27 was answering a different question, you are not enrolling in the Public Points rewards system when you do plan changes, so your good.
In order to be enrolled, you must agree to the terms and conditions and opt in to go to Public Points Rewards by clicking that white box below:
01-26-2023 10:59 AM - edited 01-26-2023 11:01 AM
No you will stay on your the old Rewards system but DON’T click on switching to the new Points system.
01-26-2023 10:53 AM
@francis100 No worry, changing plan won't affect rewards
So, you can change plan and stay on the old rewards
