4 hours ago
3 hours ago
hi @Accountant it's quick, does not need much time. Just login My Account and change it in Profile, Manage EverSafe id
3 hours ago
@Accountant wrote:Let me know if it takes time to change?
First, you need to know we are ALL customers like you. Only YOU know if it's changed, nobody here. And if you change it, it's changed. That easy.
3 hours ago - last edited 3 hours ago
@Accountant It should be instant , when you try to login again clear webrowser cache and cookies . Open new window and use incognito mode / private mode or try the app instead or from another device even might be cache issue
3 hours ago
4 hours ago
@Accountant wrote:oh, yes, thank you. unfortunately, it's not user-friendly! I spent much time figuring out how I could change it.
I hate to say this but I agree with folks like @Accountant who don't use the site often. Here is a perfect example.
Entered "How to change your home address" into the Find Answers Fast and searched. Look what came up. NOTHING about changing your address. This is a serious issue that needs a resolution.
4 hours ago
4 hours ago
Hello @Accountant
It's super easy to do. This is a self serve provider. So just log into your account, on the left side you'll see Profile, click on it and then the next page on the right side is the Account Info box. Account Name is your name, click the pencil right beside it and on the next page you'll be able to change your address. Enjoy.
4 hours ago
@Accountant You can do that in your account profile page . Tap the pencil next to your name and change it
