yesterday
yesterday
Just login my account on the PM app with no problem.
Login with your registered email address and password. You can click on Forgot Password.
If all fail, contact a CS_Agent by typing in Submit a Ticket on the Chat Bubble.
yesterday
@harrypankratz Try from another device if using website try the app instead. . When using the website try incognito /private mode . If you see option that says “didn’t get code “ tap it and you should get option to send code to email . If still no luck get support to help you gain access
