Red dot notification on iPhone
MG8
Does anyone else get the red dot on their iPhone “Phone” app?  I believe it comes up when I get a voicemail, but it doesn’t always go away right away after I’ve listened to and deleted all my voicemails.  Anybody have tips on how to get rid of the red dot?  I did not have this issue with my previous provider using voicemail
13 REPLIES 13
NATAS
essentially what i did was call voicemail, then access personal options, then access message notifacations which was called voicemail notifacations the first time i tried this, but after enabling it. the name of it changed from voicemail to message notifactions? why i dont know... it sounds confusing but explaining it and doing it is easier done then said
NATAS
yes it was otherwise how could i of called voicemail and accessed those options
HI @NATAS
so, your voicemail was not setup earlier?
NATAS
the only way i was able to get rid of the red dot wasnt after trying every other thing suggested on here or the web was by calling voicemail and accessing the voicemail notifacation number and hearing that it wasnt enabled so i enabled it and after that "POOF" red dot gone
MG8
Sure, Thanks for the suggestion!
MG8
Not yet!  Thanks for your suggestions.  Will try updating and rebooting 🙂
MG8
Will give this a try! Thanks!
MG8
Thanks for this suggestion!
toppy
@MG8 I am the same 2, even though i have both PM and Fido Sims. It only showed the red dot for the voicemail.
umnikke8
It's just the way voicemail works with Public and iPhones, not the greatest. There isn't anything particularly wrong with your phone or settings. The system just doesn't work that great.
@MG8
There are bugs on the iOS 16 with notifications.
Try rebooting your phone by powering it off then back on.
LitlLdy
@MG8 , it has happened to me before. Please reset network settings, reboot iPhone. Let me know if it helps please.
Edit: I remember it also happened with an older IOS software update! Is yours updated to 16.5 yet?
@MG8
try this
  • Go to Settings > Notifications> Phone> then turn OFF Badge App button. The red dot should disappear from the phone icon.
  •  Call yourself from another phone and leave a message > Call voicemail and delete your message.
  • Go back to Settings > Notifications> Phone> then turn ON Badge App button.
