change from eSim to Sim
JS-yu
Hi,
I accidentally chose esim instead of sim when purchasing the plan. I have not activated yet, and I wonder if there is a way to switch to sim.
Thanks.
HI @JS-yu
you likely cannot login to My Accoun to make the change yourself, please ask agent to help
please submit a ticket with CS Agent here:
and better to buy the sim card yourself first, get one from Telus or Koodo store
@JS-yu  You will need help of support
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
Add best to get SIM card from Amazon $4.99 there
HALIMACS
Yes.
Contact the customer support agents to have them reverse the esim and pick up a public mobile physical SIM card at a local corporate Telus or Koodo location
To contact a Customer Support Agent, send a private message to them by clicking here.  You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
