cant make or receive calls that are toll free.
oliviaJ
Anytime I get a call or try to make a call that is toll free - it stops and says call failed. I need to get ahold of a government agency and cannot because of this. I have tried other toll free numbers to ensure that it is not the government systems that are down but nothing works. The only numbers that work are local with a 403 area code. Please help.
8 REPLIES 8
HI @oliviaJ
 iOS or iPadOS 15 or later, tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings
@oliviaJ  Go to setting app on iPhone >cellular >cellular data network > rest network
oliviaJ
Thanks - Im trying to figure out how to reset all networks on an iphone but cannot seem to locate it.
oliviaJ
How do you reset all networks on an iphone. I cant find it.
oliviaJ
These numbers worked for me before. It shouldnt be an issue but thanks for letting me know.
@oliviaJ  Not all 1 800 numbers work with PM also
@oliviaJ
first, as a workaround, you can download free VoIP app TextNow and make the calls using the app
For your phone issue, try to reboot it once
If issue persists, pleae try Reset all networks and see if it helps
And do you have another phone to test your PM sim card?  Try that
If nothing help, message support and ask them to refresh your account
HI @oliviaJ
reboot the phone first
and try Reset All networks
