01-26-2026 10:52 PM
after i pay, and choose a number, the activation doesnt go through
01-26-2026 10:55 PM
@SPC2025 - What type of error are you receiving?
I am not an Agent OR a person working or is fully affiliated with Public Mobile! To contact an agent, Click Here
01-26-2026 10:54 PM
hi @SPC2025
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
if not, ask PM support agent to help, you can submit ticket by direct message:
