cannot update to android 10 on note 9 960U AT&T unlocked
obi
Hi,
I was wondering how can I update my note 9 960U which is originally an AT&T unlocked phone to android 10. Everytime i check the software updates, it says its up to date. Does public mobile not provide OTA software updates? I've tried using smart switch on the PC, still says my phone is up to date on android 9
cellphoneuser1
@obi Can you borrow or buy an AT&T sim? It doesn't need to be active. Put it in your phone and check for updates on wifi.
popping
@obi
AT&T is controlling when to release update for their phone. PM has nothing to do with AT&T phone.
It may be your phone already has the latest firmware.
@obi wrote:
Hi,
Public Mobile does not update devices. They don't sell any. Updates can either come from the manufacturer or the original carrier.  You could use ODIN, but proceed at your own risk as you could end up breaking your device if a mistake is made during the process, and the process also erases all content stored on your phone.
