10 hours ago - last edited 6 seconds ago by computergeek541
I switched to Public Mobile three days ago, and since then, I’ve been unable to receive texts. I cannot receive SMS messages or send texts to anyone using an Android device, although I do have cellular service.
Shortly after my switch to Public Mobile, I received a text indicating there was a problem, which I've attached below. The URL in the text is also inaccessible.
Since then, I have struggled to resolve this issue on my own.
I hope this group can help. Thank you in advance!
9 hours ago
Call the number in the link below to obtain support for a stuck port.
10 hours ago - last edited 10 hours ago
hi @MarkW709
the number not ported yet. Check with PM porting support team and confirm. Also, you should provide them the account number of your old carrier instead of IMEI
I will send you the number to PM Porting support team Please check your community inbox
