Im registered with PM, no problem. The problem is I'm not connected to the phone,. Can't connect to
FWhite
2 REPLIES 2
gblackma
@FWhite please log into your self sevice account and choose the change sim option and compare the last 4 digits to the sim card in your phone. The Sims should match.
 If they don't, then you may have been sim jacked. Change your password and name on the account.  Immediately place your phone on lost/ stolen. Change email, bank, credit card passwords that may be at risk. Contact the relevant places.
If they do try the lost/ stolen trick to reset your service. From your self service account enable the lost/ stolen feature log out, wait 5  minutes, log in and take it off. Log out and restart your phone.
 In both cases, contact the moderators. In the former contact them and ask them to switch your service back to the original SIM card. In the latter, contact them and ask them to reset your service.
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
HI @FWhite  - Welcome to PM!
Try:
*a full reboot on your phone
*removing and reinserting your SIM
*going into airplane mode for 5 mintues and then turning off
Did you port a phone number? Your should have some services right away.
*Cell phone porting can take a few hours to complete
*Landline can take up to 7 days to complete
What type of phone do you have?
