11-10-2019 12:31 PM - edited 01-05-2022 07:55 AM
11-10-2019 05:45 PM
@oynah99 wrote:Hi
I can receive text messages ( sms), but when I send or reply to text messages , the recipients do not receive them.
I have removed my sim card and try it on another phone, I still am not able to send text messages (sms)
Please advise, thank you
Had you purchased and used a US roaming texting add-on? Is it somewhere around it's expiry?
11-10-2019 04:39 PM - edited 11-10-2019 04:43 PM
By any chance did you just recently port over to Public Mobile? On some Android phones after porting over, text messages cannot be sent if there is an existing messsage thread with a convrsations with that person. If that's the case, the solution is delete the thread and to start a new one, but note this will delete any information in the messsages to and from that person.
11-10-2019 01:40 PM
His about this?
11-10-2019 01:23 PM
Best to contact a moderator by clicking? and following instructions, if isssue persists.
11-10-2019 01:00 PM
@88cranston wrote:
@oynah99 wrote:Thank you
My phone is Samsung A 50.
All persons I try to send text do not receive them
Try this
That link is for MMS @oynah99 cannot send SMS not the same.
11-10-2019 12:55 PM
11-10-2019 12:51 PM
Thank you
11-10-2019 12:42 PM
@oynah99 Go into settings Apps select the app you use to send messages, clear cache and data and then select force stop. Restart your phone and try sending a text to see if it works.
11-10-2019
12:38 PM
11-10-2019
04:38 PM
computergeek541
@oynah99 wrote:Hi
My tel no. is xxxxxxxxxxxxxxxx and I have a 25$ monthly plan with Public Mobile.
Do you have an iPhone?
Do who you text to have iPhones?
If iPhones are you texting to a phone number or email address?
edited by computergeek541: personal information removed
11-10-2019 12:33 PM
@oynah99 you should remove your phone number from this public community by clicking on the 3 dots to the right of the post and click edit! What kind of phone is it? Does nobody receive your text or just 1 person? Could be that they have your number blocked.
