resend transfer number message
geraldinegrace
I need to get the confirmation for transfer my number to Public Mobile. I missed the 90 minute mark and was not able to reply YES to the previous message
Sent . Check community inbox
EricE
Can you please send me the number too.  Thanks
normal to be to make calls but not receive for now.  Usually port is completed in 30 mins to 4 hours.  So, try reboot the phone often and test incoming calls
and make sure you remove the sim card of the old provider (or disable the old esim)
geraldinegrace
I called and got them to notify my previous provider. Got the message again and responded YES to it. How long do I expect my number to be working again? So far I am not getting texts or sending. But I can call outbound. Not receive calls inbound.
hi @geraldinegrace
 PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
slusagm
there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
