cannot connect to USA network for roaming,
Florakan1
Florakan1
Customer agent, give back the 25 dollars credit to my account.  At least they are responsible for the add-on error. The agent is helpful.
Florakan1
I went back to Canada already, thank you.
Are you in Alaska @Florakan1 ?
Can you try your PM SIM card in a different device to see if it can connect to available US networks?
@Florakan1 Help us, help you. You gotta give us more than that if you want help. We are just customers, like you. I gave a few suggestions and asked a number of questions to help us narrow down your problem.
Florakan1
Thanks, There is no T-Mobile to connect. only AT&T, but cannot connect
DennyCrane
Do you have any bars? From your phone do you have your Network Selection set to Automatic? If that isn't working, try to manually connect to T-Mobile. Also try setting your Preferred Network to 4G rather than 5G.
Where are you in the US? Did you purchase a US roaming add-on? If so, which one? Does it include calls, texts, data? All of the above? It needs to say Roaming; international long distance and texting is not the same as roaming. Or do you have a Can/US plan? Is your plan at home active?
What phone are you using?
