cannot activate without app?
troog08
so im trying to get my sons old galaxy s5 neo online with a sim BUT i cant figure out how to activate it....keeps saying to download the app BUT the phone is too old for the app and is unsupported and wont download!!!!
Yosemite_Sam
You can do online on a computer.
dust2dust
I'm pretty sure those lower plans are available on the website activation method too. Sent you a message.
Adding - don't forget to use your referral code.
@troog08   If you are activating $39 plans and above , you can go to the site https://www.publicmobile.ca/en/bc/plans  , pick a plan and click Subscribe now and follow the activation step on line
But if you are trying to activate $25 and $15 plan, then you will need to ask your friend to download the app on a newer phone and activate it on the app for your. $25 and $15 plans are ONLY available on the app
@troog08  you can activate in the website also , but if you want the $15 0r $25 plan at activation then it’s needs to be done in the app
