08-31-2023 12:35 PM
I received a text message for a new PM plan opportunity, but instead of hitting delete, I mistakenly said yes to the offer. I do not want to change my plan, how do I correct this error of hitting the wrong key?
08-31-2023 12:42 PM
HI @Sara2023
login to My Account using Incognito/Private/Secret mode, go to Change Subscription page and you will see a plan change scheduled there and you can hit Cancel
08-31-2023 12:40 PM
Log in to your account and in your subscription change plan area see if you see that a plan is scheduled for your next renewal. If not then it might be that it didn't work. We heard from someone earlier that intended to get a text offer but then it didn't happen.
08-31-2023 12:39 PM
@Sara2023 Go into your account subscription add on page . You should see your current plan and upcoming plan change . You then will have option to cancel plan change . Or get support to do it for you
Cancel plan change
send a private message To CS_Agents click
VVVVV Link below VVVVV
