cancel my account
JV2006
i have tried to activate my sim, no way possible, and there is NO signal either. So please cancel my account
LitlLdy
@JV2006 , please don’t give up yet. Try @hTideGnow  suggestion to reboot your phone & reset network settings. That fixes a few issues. If it doesn’t use the link that was provided to send a private message to a CS_Agent for help.
@JV2006  are you trying in the app from start to finish. But here got to contact support to cancel
private message   To CS_Agents click
HI @JV2006
please work with CS agent first and should be able to make it work..  You can submit ticket here:
But also, try to reboot the phone first, then click Reset all networks
If still not working, try your sim on a different phone
