2 hours ago
This Canada-usa plan, can it be use in the us just like in canda? without any extra charge
56m ago
Yes, the Canada USA plan works in both countries and you don’t need to purchase any Add-on.
Just remember to set the phone on VoLTE and you may need to connect to AT&T or T-Mobile.
an hour ago - last edited an hour ago
@Esd23 Yes. The only difference could be if you don't have a VoLTE approved phone in which case voice calls in the USA can be problematic but data and texting should still work. You may also need to drop to 4G/LTE instead of 5G for the best service in the USA. But no extra charges.
