3 weeks ago
Hi
I switched to public mobile few days ago..
I can't receive or send any sms ?!
I've done the basic troubleshooting from what I read online. I noticed under
settings > messages > send & receive
my phone number says verifying
it's been stuck at verifying for few days I turned it on and off without any luck
any help would be appreciated
thx
2 weeks ago
my issue is just with SMS, sending and receiving.
IMessage works, FaceTime works , phone calls work.
sms doesn't work. I have a side problem now I'm trying to login to the public mobile app. but EVERSAFE asks to verify with SMS to login now.
my thought process was to order a SIM card and do some troubleshooting with physical SIM with another phone rather than the ESIM.
is there a way I can get the login to my public mobile app fixed ?!?
3 weeks ago
HI @Jamaldaoud
was it just sms issue? can you get inbound calls?
if SMS, probably a problem with activation. Please ask PM agent to refresh your account.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 weeks ago - last edited 3 weeks ago
Public Mobile is dealing with issues when it comes to SMS iMessages and such. No ETA of when it will be resolved.
