12-05-2023 06:01 PM
12-05-2023 06:17 PM - edited 12-05-2023 06:17 PM
@roxana3 you can use this driver link to support to investigate
e community you can send a private message To CS_Agents
12-05-2023 06:17 PM
i can make a call but they can’t call me
12-05-2023 06:16 PM
Hi @roxana3
I too ported my number from Fongo. I'll send you the porting team number to help complete the transfer. Take a look at your mailbox in the top right corner of this page.
12-05-2023 06:10 PM
yes it was a fongo number and it is inactive right now
12-05-2023 06:07 PM - edited 12-05-2023 06:07 PM
Did you port your number recently?
Is your PM account active?
How about calling out and sending SMS?
12-05-2023 06:03 PM
@roxana3 Can you try your sim. Card in another phone to test ? Or reset network settings . See if that helps
