can not make call
Ballie
can not make call . and have messege data is not avaiable
@Ballie   be safe, login to My Account using Incognito mode and check account status first
But it could also be local network issue. So, if account status showing Active,  try the sim in different area
Ballie
it should be on june 07
@Ballie
did you try what suggested?  Look like your account now renewed, maybe Autopay failed
https://productioncommunity.publicmobile.ca/t5/Get-Support/cell-phone-is-not-working/m-p/991519/high...
